Write to spreadsheet headers?
I would temporarily put indicators on both the array of doubles and the array of strings coming out so you could compare what is actually happening.  You have used the default setting for width and precision, but those should easily show the difference between 1.34E-14 and zero.
Is it possible that your data gets rounded or set to default before getting to this part of the program?  The indicators I suggested above will help show that.
Lynn
Message 11 of 13
(767 Views)
if you change the f (i picked f since you shid you wanted a double precision) to e this will be an exponential (scientific format)  you still can specify the precision as per the example (the number after the decimal in the string formatter).
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 12 of 13
(763 Views)
Hi Pazmush,
I have found a link that I believe is exactly what you are looking for.
http://decibel.ni.com/content/docs/DOC-3817
I hope this helps.
Any problems let me know.
Kind Regards
Michael
NIUK Application Engineer
Message 13 of 13
(743 Views)
