Write to spreadsheet command limits 20 columns
I am using LabView 8.5, and an SCXI-USB for data collection.
I am working on a program that reads in four temperature channels and 20 voltage channels using two seperate loops, then I concantenate the two signals in order to write the data to a spreadsheet file with length 24 columns.
However, LabView is cutting my data up; it will post the four temperature data points followed by 16 zeros, and the next line will be my 20 voltage readings.
Is there a limit to the number of columns that can be written to a spreadsheet via LabView, or is there another issue here I do not know about?
(2,520 Views)
Accepted by cgy5002
No, there are no limitations. You are concantanating the arrays incorrectly. You should be getting a 1D array out of your Build Array function and you probably did not right click on it and check 'Concantanate Inputs'.
(2,517 Views)
