Write to spreadsheet 2D gives me zeros?
I have an array that I built going into a write to spreadsheet and although the first column comes out allright, the next three are all zeros? Could this be because they are such small numbers? and if so How do I remedy this. Here is my VI
(3,237 Views)
the subvis are missing. Can you upload the subvis too?
(3,227 Views)
Read the help for the function and change the format input.
(3,225 Views)
Hey Pazmush
I'm trying to open your VI to see whats going on, but missing some sub VIs, can you attach them for me?
(3,222 Views)
Accepted by topic author Pazmush
1) press crtl-h to open the help window.
2) Float over the write to spreadsheet function.
3) Observe input at the top labled "format".
4) Right click on SS function and choose show help.
5) Read explanation about the format input.
6) Change the format input by creating a constant and editing same for your needs.
If the format is not the issue. create a probe for that data and check to see what your real data is. It just may be zero.
Ben
(3,218 Views)
here you are
(3,181 Views)
never mind, ben is the winner! I am a fool!
(3,176 Views)
