Write to file Question
If you are going to reuse the cluster anywhere in your application and especially if you will be using it as a parameter to subVIs you should always use a typedef. Your typedef does not have to be the data you display on the front panel. You can pull out the values that you need and only display the pertinent data. However, a typedef is a MUST when you are reusing the data type in your application. It is the only way to ensure that everything gets updated properly and that all references to that data are in sync.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 21 of 33
(1,722 Views)
Right, I've got it type def'd.
I don't think that's what's holding me up right now.
My issue is with the ini file, and failing to read and write.
Message 22 of 33
(1,721 Views)
Alright, this just isn't working, I think I'll try the xlm route.
Message 23 of 33
(1,719 Views)
Accepted by krwlz101
The problem is that you're never closing the file. You need to call the Close Config Data VI with the "write" set to True.
Message 24 of 33
(1,705 Views)
THANK YOU!
I wish I could give you more than one Kudos smercurio!
Message 25 of 33
(1,701 Views)
Alright, last question for this issue.  I see where it is easy to obtain the section names, however I'm not sure how to get them into a list/combobox/menu ring, etc.
Message 26 of 33
(1,696 Views)
Use the Strings[] property or the Item Names[] property, depending on which control you're using. The LabVIEW Help has information on the available properties for each type of control.
Message 27 of 33
(1,690 Views)
Got it.  Don't know why I always forget about property nodes.
Message 28 of 33
(1,689 Views)
Hey,  You're still learning!  you won't always forget Smiley Wink
Nice thread- sorry it took me so long to check back in.  Glad the others showed up with good advice for you.
 That being said-  I'll chime in on a couple of points that Christian and Mark debate:
  1. INI vs XML-  XML is quite powerful and widely used.  understandng the schema (the "formatting Rules") is key to unlocking the power of XML.  IMHO there is not a true standardized schema with univesal acceptance so the format is too limited in scope for a truely portable solution.  you can't garantee the LV XML schema is compatable with VB,  MS Office apps, c# etc....  Maybe someday..  but certainly a structure form to watch!  .ini on the other hand lacks some ability in that there is no native way to format a complex data structure.  Ben has posted a solution to this and I have overcome the shortcommings in other manners as well but you need to code the solution to write data structures to an ini.  My preferance TODAY is to go with the .ini as its human readable (with notepad).  LabVIEW itself uses a .ini for configuration settings.
  2. TO OpenG or not to OpenG whether tis better to suffer the slings and arrows.....  It there - Its open - its free.  And its there today.  As a guide for reuse code its great!  I'll "waste the time" to code my library simillar but do not use the library myself.  Maintainablity is my only isssue with it.  With all due respect to the OpenG community (Truely- my hat's off to them all) there is no mandate for maintaing the code and my NI SSP is paid up.
"Should be" isn't "Is" -Jay
Message 29 of 33
(1,623 Views)
There is no standardized schema for XML. There was never meant to be one. The XML spec doesn't define what your schema is supposed to be. That's for you to decide based on what information you have to transport. Remember that the initial purpose of XML was to provide a generalize encoding method to transport information. Given that, how can there be a standardized schema when there is no standardized information?
... so the format is too limited in scope for a truely portable solution.
Too "limited in scope for a truely [sic] portable solution"? This I disagree with 100%. I think you have a basic misunderstanding of the purpose of XML.
Why should the LV XML schema be compatible with VB, Office, or anything else for that matter? Consequently, there is no reason why the reverse should be true.
XML doesn't need to be watched anymore. It's been around for more than 10 years. I think it's proven itself quite well.
XML is just as human-readable as INI files. Besides, what difference does it make what format is used by LabVIEW for configuration settings?
  1. TO OpenG or not to OpenG whether tis better to suffer the slings and arrows.....  It there - Its open - its free.  And its there today.  As a guide for reuse code its great!  I'll "waste the time" to code my library simillar but do not use the library myself.  Maintainablity is my only isssue with it.  With all due respect to the OpenG community (Truely- my hat's off to them all) there is no mandate for maintaing the code and my NI SSP is paid up.
I don't quite understand your point about maintaining the library. It seems as if your point is more general in that it relates to open-source code, rather than OpenG specifically.
Message 30 of 33
(1,617 Views)
