Write to a file at different frequency?
Hello:
I want to represent in a waveform chart two variables every 200 ms. That is what I'm doing in the attached vi. But I also want to write on a measurement file this two variables at a variable rate (user can change it). Where or how can I put my "Write to measurement file"?
Please, see the attached vi.
(3,319 Views)
Hi damos,
without being able to look at your VI I would suggest two ways:
- make a Case structure to call the Write-VI every n-th iteration
- put the Write-Vi in a parallel loop
(3,289 Views)
Thanks GerdW for your answer but I don't know how can I do it:
1) With Case structure, I don't know what to do with the output tunnel on the false case because out of the while loop I have a tdms file viewer.
2) With parallel loop, it doesn't transmit the data from one loop to another.
The original vi is this. Where or how can I put my "Write to measurement file" to write variables at different rate of main timed loop (200 ms) ?
I attached VI again for previous versions of labview. Thanks.
(3,275 Views)
Accepted by topic author damos
Hi damos,
"With Case structure, I don't know what to do with the output tunnel on the false case"
In that case, I would suggest going through examples provided with LabVIEW or to read the LabVIEWBasics-course on the NI website...
Admin note: Broken Image has been removed.
(3,270 Views)
Thanks a lot, GerdW. With your solution it works perferctly. I hadn't thought with shift registers.
(3,263 Views)
