Write to Text File not working...
So I have a little test script to try and get writing to text files working. However, nothing happens. I also tried creating the text file within the path I declared in my VI, and its still not working. I'm sure its an easy fix but any help is greatly appreciated.
Using Labview 2020 64-bit.
(3,538 Views)
Accepted by David99999
Hi David,
when you want to create a file then you should actually "create" it - and not just use the "open"-mode of FileOpen…
(3,533 Views)
1. I typically use the "Create or Replace" operation when creating a log file.  The access input can be left unwired.
2. I am noticing your loop never stops.  So you can never close the file or get the error dialog if there is an error.  Have the loop stop with an error or a button.
(3,528 Views)
Welp, that was an easy one. Thanks guys, I'm sure you know how it goes when drinking from a fire hose XD
(3,439 Views)
