Write string to ini file problem
i was tring to write a string to a ini file , that should be :
[Basic Information]
File Name=C:\\11111.doc
but the result is :
[Basic Information]
File Name="C:\\11111.doc"
where did the double quotation came from?
Message 1 of 10
(9,045 Views)
Hi adobe,
please switch on the context help. Then you would recognize the additional input of "WriteKey" when writing strings...
Other topics:
- Why do you convert the path to a string? Why not write the path directly?
- Why do you use locals here?
- Why do you complain about the quotation marks? When reading the key they will be filtered by LabView anyway...
Message 2 of 10
(9,031 Views)
     i don't think there is any connection with converting path to string, becaus i met the same question in following block diagram , and i have tried to switch "wirte vi" type from automatic to string , also can't work
Message Edited by adobefree@gmail.com on 12-03-2009 04:17 AM
Message 3 of 10
(9,024 Views)
Hi adobe,
the quotes are written because NI programmed the WriteKey/ReadKey-functions that way. (Hint: just look at those function's block diagram...)
You didn't answer why you don't want them...
Message 4 of 10
(9,014 Views)
                   i have show the same problem without converting path to string , mostly this problem happended after i use string format function
                  i was using a stacked sequence strcuture , while there was so much frame, and i don't want to use to much
sequence local ,so i use local variable ,for example if i want to swith the following block to stacked sequence strcuture, each vi per frame ,
             how much sequence local  do i need to use? , my solution is to feed the same Local variable in each frame ,or do you have any good idea?
                 it was specified format by customer
Message 5 of 10
(9,010 Views)
Hi adobe,
either:
- Filter the ini-file after writing to remove the quotes
- Change and use a copy of the WriteKeyString function
The config file functions are nice to use, but they have their quirks NI-specific implementations...
Message Edited by GerdW on 12-03-2009 11:45 AM
Message 6 of 10
(9,007 Views)
Accepted by topic author adobefree@gmail.com
 got it ,thanks
Message Edited by adobefree@gmail.com on 12-03-2009 06:29 AM
Message 7 of 10
(8,987 Views)
Ran into the same issue with quotes being added to the value in LV 2009 forward.  fwiw, I've attached a drop in replacement for Write Key (String).vi that doesn't write quotes or escape characters to the file. I just tore out all of the privately scoped subVIs from Add Key.vi so there's one monolithic diagram with no library dependency.
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 8 of 10
(8,215 Views)
save it please for previous version if possible (2009), not (2013). thank you.
Message 9 of 10
(8,091 Views)
Conversion was done here: http://forums.ni.com/t5/Version-Conversion/from-2013-to-2009/m-p/3092368#U3092368
Message 10 of 10
(8,069 Views)
