Hi!
I like to write a value in a string in an array of 12 elements. If I
connect the array to the string LV say I should insert the created array.
So I insert a "build array". But I will fill 12 elements in this array
with this string (preconditioned there is a concomitant connection between
my choosen ports). I thougt I must tow this build array to 12. But what
should I connect before? It is the same string, so I connected this, but
now it wrote the string everytome in the array elements.
What must I do?
Sarah
LV 7.1.1
