Write in output DIO d-sub db25
Hi to all,
I am using a industrial PC which have incorporates a DIO d-sub db25 port wich has 8 outputs:image.pngMy question is:
How can I program output 1 with labview? I mean open/close de output (0 or 1).
Thanks a lot.
(3,310 Views)
You need to know the model of the PC, the DIO card and the drivers.
There might be a LabVIEW driver for the card, but without the model we can't help you.
(3,285 Views)
Hi @dkfire , thanks a lot for replying.
I was doing research about this.
DIO card has a drivers (.dll library), in this library there are 3 functions (initialitation(), set() and get()).
I was checking tutorial about .dll libraries and labview, so I thing that it could be enought implementing that library in my application, am I correct?
Thanks a lot.
(3,251 Views)
Accepted by topic author Alvaro.S
Just make wrapper VIs around the Call Library Reference Node for each of those functions and you should be fine.
(3,232 Views)
