Write header and mixed data to spreadsheet
Hi everyone,
I am having some problems writing my data to a spreadsheet file... Basically, I have crunched my data and obtained the values I want... When I stop the the loop I want the data to be saved to a spreadheet file... The first line should be a header, and the lines below should be the corresponding data consisting of a string and numerical data... See example below.
Subject Name, Max Force (N), Mean Force (N), Min Force (N);
David, 2134, 23, 284;
Phil, 1234, 43, 321;
Tina, 4059, 335, 55;
Can anyone please help with this?
Kind regards,
Jack
(3,964 Views)
Since you are writing everything at the end, convert your array of data to string, and then prepend your row of headers.
(3,954 Views)
Accepted by topic author jcannon
this will create a file(test.csv), checks if file exists(no: creates header plus data...if yes:appends data only):save vi to a folder first...test.csv will be saved in that folder also.
(3,952 Views)
Hi apok,
Thanks heaps for this... Works a treat!
I made a couple of changes... See attached anyone interested...
Kind regards,
Jack
(3,896 Views)
