Write XML string to file (array)?
What is the purpose of the Write XML string to File (array).vi? This polymorphic vi accepts XML srings or arrays. If I send it an array of XML data (for example, take a cluster, flatten to XML, make an array of these, then input this to the Write XML String to File.vi), it writes the file fine. But how do you read it back later? I can read the file, but the Unflatten from XML function returns an error "The XML tag describing the type of data is not recognized". Any explanation of this? Thanks!
(4,602 Views)
Hi Sal.
I am not at my work machine so I willl try to answer from memory.
Is there another input to the VI that lets you wire a cluster that the VI can use as a descriptor?
Second thought, are you un-winding the array before trying to do the "Unflatten..."?
Ben
(4,602 Views)
Simply send to graze Write to XML File and use next dataflow:
1.. Flatten to XML.vi
2.. Escape XML.vi
3.. Write Characters to File.vi
4.. Read Characters from File.vi
5.. Unescape XML.vi
6.. Unflatten from XML.vi
"sal" wrote in message
news:5065000000080000005F4D0000-1023576873000@exchange.ni.com...
> XML tag desc
(4,602 Views)
In addition to the answers above, try using the attached VI to read LabVIEW XML data fragments from an XML file written in LabVIEW.
Also, remember that Unflatten From XML only accepts an XML fragment which contains code matching the wired type.
(4,602 Views)
