Write String Real Estate Problem
Hi all,
I have a state machine.  For each state, I am writing a long string into a string indicator.  The string from each state append to the string from the previous state through a shift register.
My problem is for each state, I am writing a pretty long string onto the indicator, and I want the string to be visible on the block diagram, and it is giving me some space problem.  I guess it doesn't have to be on the block diagram, but it needs to be somewhere that is more visible.
Any tips on that?
Yik
(3,554 Views)
Hi jyang72211,
   You need to right click on the string indicator and select the show vertical scroll bar option.Along with this you try to reduce the size of the string indicator.
 Thanks and regards,
srikrishnaNF :smileyindifferent:
Srikrishna
(3,547 Views)
"real estate"? 😁
(1,973 Views)
