Write Delimited to File without the actual function
Hey guys, looking to continuously write data to a spreadsheet. I know the Write Delimited to File would work well here, but I am using 2014 version and do not have. How could I code my VI to do this? It is attached.
(1,892 Views)
I think you can use Array to spreadsheet String to convert 2D array into string , then just use write file.
(1,868 Views)
Accepted by parker300
I use the file primitives these days because this method has a couple advantages.
  1. It opens the file once and closes the file once
    1. This has a performance advantage over Write to Delimited Spreadsheet because that VI opens and closes the file on every write
  2. Having the file open prevents users or other program from opening the file while the LabVIEW program is running.
    1. Windows will Lock the file access preventing a Sharing Violation that will crash your LabVIEW if someone open the file between writes while using Write to Delimited Spreadsheet
=== Engineer Ambiguously ===
(1,863 Views)
The old version of the Write Delimited Text File was the Write To Spreadsheet File VI.  But since you are continuously writing data, use the primitives as already stated.  Use Array To Spreadsheet String to convert your data into a string and then write that string with Write To Text File.  Open/Create the file before your loop and close it after the loop.
(1,831 Views)
