Write 12-bit TIFF with LV
As Tom Landry once said after a loss of 13-6..."It was a team effort."  I think all of it mattered.  The cast, the color pallet...all of it.
Just glad I could help push for a change.
Hummer1
Message 11 of 17
(2,076 Views)
To make things easier I'll leave yours as the solution and I'll get them Kuods together.
Thanks All!
Ben
PS No, I don't have multiple accounts. I work with 7 CLA's that are always willing to help out. Smiley Tongue
Message Edited by Ben on 11-20-2009 08:20 AM
Message 12 of 17
(2,074 Views)
Sometimes brilliance is unrewarded, and other times your SWAG (stupid wild-*&^ guess) pays handsomely.  I try to cause more problems than I solve around here so another solution would just cause trouble.  Smiley Very Happy
I believe things worked out nicely, thanks.
Always remember:  Caveat Type Caster (in all of its forms)
Message Edited by Darin.K on 11-20-2009 09:12 AM
Message 13 of 17
(2,046 Views)
Hi Hummer,
Can you post an earlier version 8.6 of the image write.VI
Message 14 of 17
(1,912 Views)
Here you go. I saved it back to 8.0.
Justin Parker
Product Support Engineer
Message 15 of 17
(1,859 Views)
When I use this (trying to write an I16 image) labview seems to add 32767 to every pixel, so that I appear to have
a U16 image scaled from 32767 to 65536.  Is there anything I can do to prevent this atrocity?
Jeremy.
Message 16 of 17
(1,747 Views)
While it is true that the initial and final values are the same - they do not appear to write to the
tiff file the same.  That is, the tiff file writer arbitrarily adds 32767 to each value for display in the
image.  When the file is read this extraneous 32767 is stripped, but if you care about the gray
scale values in your tiff file then you are still out of luck.
Is there any solution to write the values you are actually interested in to the tiff file?
Jeremy.
Message 17 of 17
(1,745 Views)
