Wrap in to string Indicator
Accepted by topic author Alwin_Capsys
Very much thank you for the reply. And this is what I wanted. Thanks a lot.
Message 11 of 22
(2,033 Views)
Hi, sorry for the inconvenience caused. I thought that single image itself will be enough to explain my requirement. But anyhow, your answer is also working fine. Thank you all for the wonderful support.
Message 12 of 22
(2,026 Views)
In addition to that, Is there any possibility to control the autoscroll property of a String indicator programmatically (using a Boolean control Autoscroll ON/OFF).
Message 13 of 22
(1,968 Views)
Hi Alwin,
there is a property to set the horizontal vertical scroll position: Text.ScrollPosition…
Message 14 of 22
(1,947 Views)
Sorry to add. I need vertical Scroll bar property!!! Any option.
Message 15 of 22
(1,935 Views)
Hi Alwin,
You can set the vertical scroll position using the property I mentioned in the last message…
Message 16 of 22
(1,922 Views)
Neglect Block diagram in this above mentioned example.
My requirement is , my string Indicator will be keep on updating. So vertical scroll bar is required and when string indicator keeps on updating, scroll bar also automatically moving.
In order to avoid this, I have placed a Boolean switch to turn off/On this autoscrolling. Is it possible to control this automovement of string scrollbar by clicking on that Boolean control?
When Boolean ON, scroll bar should move automatically.
When Boolean OFF, scroll bar should not move automatically.
Message 17 of 22
(1,916 Views)
Hi Alwin,
Not directly.
But: When button is TRUE then you can set a fixed value to ScrollPos…
Btw. set value first, then ScrollPos.
Message 18 of 22
(1,901 Views)
But if I set some value also, when data comes continuously, the scroll bar keep on moving right?  User won't be able to stop this movement and analyze a particular data properly?
Message 19 of 22
(1,875 Views)
Seems like this is what you want. Put this inside your while loop.
(False case is empty)
Message 20 of 22
(1,874 Views)
