NI Vision Acquisition for Labview 2018
I am currently working in Labview 2018 and i would like to use the IMAQ vision software, however the compatible version of VAS is not available in NI package manager. what do i do?
(1,627 Views)
I believe that VAS is a separate Product, with its own license.  Check with NI on acquiring a license.
(1,574 Views)
You will have to buy a license for Vision Acquisition Software, which has the basic drivers. There is also the Vision Development Module, which has many more image functions for a lot more money. You can purchase a VAS license here. If you don't purchase a license, you can use a 7-day trial of the software.
First you go here to see what versions are compatible with LV 2018. You can see that you want VAS 18.0 - 21.0. There is also a VAS 2022 Q3, which is not on the chart yet. But, generally, drivers are compatible with a LabVIEW version for 5 releases, so I would stick to something between 18.0 and 21.0 just to be safe.
Then you go here to download the version you want.
(1,542 Views)
