Working with elapsed time express VI
I am trying to use the express VI "Elapsed Time" to control the execution of an application of mine for a specified number of seconds.  The VI works perfectly if I give a "start time" of 0 seconds and let's take for the sake of example, a "time target" of 5 seconds.  The VI runs for 5 seconds and stops as expected at the end of 5 seconds.
However, if I input a "start time" of 1 second and the "time target" as 5 seconds, ideally, the VI should run for 5 seconds from the "start time".  To my surprise, it stops execution after 1 iteration and displays a value 3.21sec as the "elapsed time".  I get the same output for "elapsed time" even if I input a higher value such as 10 seconds as the "start time".  Attached you will find the VI I made. I would appreciate any help with respect to advising as to why the VI behaves so.
Thanks.
Ram
(6,075 Views)
The reason that you are getting 3.21 is because that is the time that has elapsed since Jan 1 12 am 1904 (the actual number you are seeing is something like 3.2155+9 if you make your elapsed time indicator larger).
If I understand you correctly, if the user sets a start time of 2, and a time target of 5, the eplased time should read 7.
See if this VI does the trick for you.
Kenny
Kenny
(6,063 Views)
Hi Kenny,
You are exactly right.  Unfortunately, I don't see anything in the VI you uploaded.  Can you resend the VI?
Thanks.
Ram
(6,053 Views)
I created the VI in labview 8.0  Also, the only difference is the addition of a delay routine in front of the while loop.  Here is a screen shot.
Kenny
Kenny
(6,049 Views)
Hi Kenny,
Thanks for your fast response.  Actually, I tried something very similar by using a while loop instead of a sequence structure.  The new VI I have is attached.
Ram
(6,038 Views)
