07-05-2024 11:53 AM
Any idea why I can't open labview on my laptop?
I'm on a Windows laptop and I downloaded the Windows 2024 Q1 version for both "Base, Full, Professional" (64-bit) and "Community" (32-bit), but neither of them would open. The programs are installed into the laptop, but when I try to open them, it takes to the blank loading page and then just stops the program and exits out.
I know I can't provide a lot of information here (because I'm kind of at a loss_, but is there anything anyone can think of that's causing this / how to fix it? I really need to work on labview 😞
Thank you in advance!!
07-05-2024 01:24 PM
Is this work or personal laptop? do you have any antivirus that may be blocking?
07-05-2024 02:29 PM
It's a work laptop, and I can't find any antivirus that I can find. I have Winows Security but I don't think it's blocking it.
07-05-2024 03:34 PM
Can you describe (in broad strokes) the steps that you go through? Installing LabVIEW without any experience in doing this can be tricky.
When the process starts, you should be confronted with the NI Package Manager (called NIPM, for short). This installs LabVIEW "packages" on your computer. There are a lot of packages that you could install, but if you are a beginner, you should install the bare minimum, and then add a package when you need to "go to the next level".
Here (a bit from memory, so I might not have things exactly right) is how I would advise you to proceed:
Should you need to "Start Over", the first step should be to "undo everything", safely. Here is my suggestion for the easiest and safest way to do this:
Whew. Good luck.
07-05-2024 04:10 PM
Just an aside, if you "really need to work on LabVIEW", it is highly likely that LV Community Edition is not for you, especially if this a work laptop. You could run legally afoul of NI/Emerson, your work place, or both. There are restrictions on usage; make sure your use case applies.
07-06-2024 09:09 AM
If this is a "work laptop", there could be a lot of policies implemented. Have you talked to IT about it?
You said that the programs are "installed". Can we assume that you had no problems running NI package manager? If you open NIPM once more, does it correctly show what you think is installed? Can you show us a screenshot?
07-06-2024 11:00 PM
Try to open Windows Event Viewer, navigate to Application Log and check Error entries. When application "silently" closed on crash or other reason, it is logged in most cases (but not always). Anyway, just take a look.
