Wire: Function Conflict, Static VI Reference
Hello Community,
Sorry if this has already been answered before, but I have spent an hour searching. I am trying to learn a little about using subVIs to clean up my code.
I'm trying to connect a static VI reference of a Gaussian function that I made to the Nonlinear Curve Fit.vi, but I get a broken wire which says "function conflict".
When I create constants for the output of my Gaussian VI and the input of the Nonlinear Curve Fit.vi, they are clearly different classes.
Could someone show me how to edit my Gaussian VI to match the class properly? I'd greatly appreciate it.
-Patrick
(3,923 Views)
Accepted by 帕特里克
Your model subvi needs a connector pattern that is identical to the template. Start with the template mentioned in the help and only modify the code, not the existing controls and indicators. Simply leave unused terminals disconnect, don't delete them.
(3,918 Views)
Yes, you can do what @ mentioned, or click the corresponding variables one by one, from your model's front panel like shown here:
LabView wants you to match these variables, in order to make the function
(2,762 Views)
