Windows XP X OTHER Windows
I've runned a Vi that generates some senoidal signals and used the Extract Single Tone Information.vi to retrieve the amplitude. I runned the Extract Sngl tone 1000 times to measure the time to run that. Here is what I got:
1.Dell Dimension 4400 P4 2GHz Windows XP - 0.235ms
2.Compaq PIII 733 MHz Windows 2000 - 0.060ms
3.Compaq P4 1,5Ghz Win 98 - 0.054ms
4.Compaq PIII 1GHz Win 98 - 0.042ms
5.Dell Dimension 4400 P4 2GHz Linux - 0.040ms
Is windows XP that bad ? Any clues ?
Message 1 of 9
(4,290 Views)
Clues maybe, answwers no.
Is there anything else going on with the XP system? make sure there is nothing else runnign at the same time.
You shouyld also do the the Loop 1000 times more than once. Their maybe some over head invloved in loading things up at first.
Hmmm 1000 X 0.236 ms? It took the XP 3.5 minutes?
You aren't doing any screen updates or anything are you?
Make sure you are timing only the loop, and not accidently timing some other fuction as well.
XP "should not" be that bad.
There has to be another reason.
Ben
Message 2 of 9
(4,290 Views)
I've done other tests and gotten exactly the opposite trend in the response of the voerall system. You say XP but don't say whether it is XP-Home or XP-Pro. You also don't indicate what other processes are running concurrently and whether there are any device driver conflicts. I find that Dell, in particular, does a lot of OEM/VAR nonsense and that this can present particular problems. Also was the XP (whatever) a native installation or an upgrade?
When upgrading to XP-Pro it critically important to use the "Clean Install" option if you want stable and optimal performance after the upgrade.
Hope this helps.
Message 3 of 9
(4,290 Views)
This is a native installation of the Windows XP Professional. Regarding the other processes, there are some processes running in paralell, but I don't know what they mean or witch one I can finalize without having other problems.
I've included the version of the VI I've runned if you like. Thank you
Message 4 of 9
(4,290 Views)
When I run this on my systems I get a mean time value of 0.039000000
Message 5 of 9
(4,290 Views)
Should I try to reinstall Windows XP? You mention about some processes running in paralell. Do you know witch ones should I disable ?
Ricardo
Message 6 of 9
(4,290 Views)
You might want to reinstall doing a "Clean Install";however, I think the problem more likely is a driver mismatch or some other program running concurrently that is unnecessary.
The major problem with re-installing using a "Clean Install" is that you will, most likely, have to also reinstall all of your other programs and will have to relicense them as well. And that can take a long time. The "Clean Install" completely replaces the contents of the Windows folder and all of its subs....
You might want to contact NI about this before venturing down the path of reinstalling.
Message 7 of 9
(4,290 Views)
I did the reinstalling (I didn't installed from scratch) but the problem persists.
Message 8 of 9
(4,290 Views)
Did you contact NI?
Message 9 of 9
(4,290 Views)
