Windows 7 is Error reporting when running a program generated with in Labview LV 7.1!
Dear Labviewer's
Once back in the yaers I'd generated a program with  - Labview 7.1.
Now I'm informed that the version LV 7.1 is not supported by Windows 7.
Now when i try to run the Program generated by Labview 7.1.  in windows 7 , I get communication error by the serial port.
Is there somehow somthing I can do to get this work. Is there any Runtime engines From NI for Windows 7.?
Please Feed back if anyone got info for help.
4 Stars ...
HFZ
(2,902 Views)
Accepted by HFZ
Have you installed a newer version of the NI-VISA runtime engine that will work with Windows 7?
The most recent on the NI website appears to be version 5.0.3.
http://joule.ni.com/nidu/cds/view/p/id/2257/lang/en
(2,890 Views)
Thank you very much.. It worked.
How to STAR your answer .. is it removed ?
HFZ
HFZ
(2,879 Views)
The stars are now called Kudoes.  They are on the left hand side under the user name.
I'm happy you've got it working now.
(2,874 Views)
