Will LV7.0 install on W7 running XP mode?
Does anyone know if LabVIEW 7.0 executables will install and run on Windows 7 running in XP mode?
Thanks.
(2,278 Views)
I dont think it will support the drivers properly even it were to support earlier versions. See here
Message Edited by muks on 04-05-2010 07:07 PM
(2,273 Views)
(2,272 Views)
All you need to run an executable is the run-time engine.  If you are running any hardware, you will need the drivers as well and this is where you might run into problems.  The run-time engine can be found here, http://joule.ni.com/nidu/cds/view/p/id/750/lang/en.
Applications Engineer
(2,230 Views)
