Width of Hysteresis
I need to compute the width of a hysteresis plot. I have been wondering if there is built in function or a combination of them that can do this computation directly from the XYGraph.
Any ideas?
Gregorian7
Message 1 of 13
(4,775 Views)
Hi Gregorian7
Would you please send your code?
The width of hysteresis plot could be computed easily.
But before anything else clarify the parameter you want to compute on the plot. I mean the region you in the plot you name it "the width of hysteresis plot".
Hossein
Message 2 of 13
(4,743 Views)
Hi Gregorian,
So you want to calculate the x distance for the same Y data for the up and down side of your hysteresis curve/plot?
Surely there are functions to determine values of plot data (read carefully: "plot data", but not "the plot itself") like Threshold1DArray. You just need to prepare your data and combine the results…
No, THINK DATAFLOW!
The XYGraph is just an indicator for some data - you need to do the calculation with those data!
Message 3 of 13
(4,733 Views)
Hi GerdW,
Yes, that exactly what I want to achieve.
How can I be sure  if there is exactly the same Y data value for the up and down side of the plot to do the calculation?
Gregorian7
Message 4 of 13
(4,723 Views)
Hi Hossein,
I attached the picture with marked distance I'd like to calculate.
Gregorain7
Message 5 of 13
(4,721 Views)
Hi gregorian,
You can interpolate your measurement data for the same Y value…
(With usual measurement data you will never get the very same X and Y value due to random noise.)
Edit: You don't need to post the same image twice. You can even edit your own message to add text…
Message 6 of 13
(4,720 Views)
Hi GerdW,
Could you help me out a bit.
If I've got an  2D array one column represent Force and one Stroke.
What do I have to do? Index array to get a subarray with stroke values and find indexes with the same data value then search for them in force array and subtract them?
How can I interpolate data for the same Y value?
Gregorian7
Message 7 of 13
(4,709 Views)
Hi Gregorian,
Sure - as soon as you provide an example VI with some example data representing your typical plot data!
1. Separate your data into the up and the down cycle.
2. Use any of those interpolation data to find the X coordinate for the interesting Y value.
3. Do step 2 for both cycles.
4. Get the difference of both X values…
Message 8 of 13
(4,703 Views)
Hi Gregorian,
I saw the picture. It could be easily done just by a small piece of code.
Please determine two things, then I will modify your code,
1-The minimum and the maximum allowable of width. For example we say if the width is going to be bigger than x1 it's proper to compute and show the value and if it is going to be smaller than x2 then it's not proper. It's a reasonable to have an interval for allowable values, without this you don't define anything to compute. Imagine I am just a programmer and I don't have the knowledge of your test and I don't know what is hysteresis but I can implement your goal by programming, this is the reason of asking this interval.
2-If you can take a picture from the part of your LV code in block diagram which is connected to the XY-chart block. If you can send the whole program it's better and easier to modify it but the the picture I mentioned is enough for me.
Hossein
Message 9 of 13
(4,689 Views)
Hi Hossein,
Thanks for your reply.
There is no min allowable value as in  my case, hysteresis width = 0 will be a perfect situation. Max. is  9.
I have attached project to this message.
Gregorian7
Message 10 of 13
(4,670 Views)
