LEDs control with 74hc595 and Daqmx
Hey everyone,
right now Im doinig my Bachelor Thesis and I realy need help. I`d like to control many LEDs  with NI-9403 und using 4 shift register. I`ve created this Subvi but I had the problem that the programm needs long time to control the LEDs.
Could you please help me. Thans in advance
Message 1 of 12
(4,847 Views)
Hi Baron,
why don't you take none of the suggestions you got in your German LabVIEWForum thread?
Still all those sequences and unneeded FOR loops, apart from funny array handling.
Unfortunately you didn't say which DAQ hardware you use - in the last 2 month…
Message 2 of 12
(4,811 Views)
I think I can´t use  hardware timing with NI 9403. It can be used only as a static (software-timed) digital I/O module.
Message 3 of 12
(4,791 Views)
Hi Baron,
then why do you ask for speed improvements when your hardware doesn't support them?
Message 4 of 12
(4,786 Views)
because the CompactRIO chassis are too expensive. Smiley Frustrated
Message 5 of 12
(4,781 Views)
Hi Baron,
you don't need a cRIO. You need something being able to output digital waveforms!
Btw. "being expensive" is no LabVIEW problem. It's an accounting problem of your company…
(You are working on this for two month now. This would be much more than 10000€ for my company, if I would spend time on this problem…)
Message 6 of 12
(4,770 Views)
Do you Know what exactly I need?  And Could you please make me an easy example with how to genrate two digital signals for two channels as waveform and tansmit it to the NI-Modul.
I´m realy thankful for any help.
Baron
Message 7 of 12
(4,759 Views)
What chassis do you use? Even a single slot chassis 9171 provides the functionality to use digital waveforms on a 9403 module. Have a look at the examples in the NI example finder - there should be something suitable.
Jens
Kudos are welcome...
Message 8 of 12
(4,745 Views)
Hi Jens,
I use cDAQ-9171. I couldn untersand the example (Pipelined Sample Clock) und how to use it with my problem.
Message 9 of 12
(4,742 Views)
I'm not sure if that example is applicable for a 9403 in a cDAQ chassis, but the Finite Output example should work with this module - at least it does when I simulate that hardware.
Now you "just" have to create digital patterns for all the lines that you need to output in parallel, put that together and send it to your 9403.
Jens
Message 10 of 12
(4,724 Views)
