Why with double x-axis graph the scroll-bar move only the first
I'm using a Graph with more than one plots and 2 x-axis. Some plots  are connected with the first x-axis the others to the second one.
When I use the scroll-bar the graph show me the movement only for the plots connected to the first axis. Can someone tell me why?
What can i do to move all the plots toghether with x-scroll-bar?
greetings
(3,549 Views)
Accepted by topic author PincoG
I did some tests confirming your behaviour: I think that the X scrollbar that can be made visible for waveform graphs is only associated to the first X scale.
To scroll all the traces, I found this possible solution: mimic the behaviour of the scrollbar with a slide control and property nodes to set the range of the X scale to be visible, as described here. Using the graph property "Active X Scale", you can set which scale is active and so to which scale the different other properties must be applied.
I modified the example to add this functionality: in this way, both plots are scrolled when the avlue of the slide is changed.
I hope this can be a solution for you!
Bye!
Licia
(3,531 Views)
ThankYou a lot for the idea, now i have to work around it, beacouse  it's too easy in that way, (what use can have a graph with two scales with the same value?). I have to try, in the while thanks a lot.
Bye
(3,522 Views)
