Why replay history data from NI-DAQ buffer?
LabVIEW 8.6.1f1, NI-DAQ 8.8, Win Vista, two cDAQ chassis.  (I can't move to LV09 or LV10 for this, not yet anyway).
I have a client with two cDAQ banks, each with 16 TC channels (on 4 modules) and 16 voltage channels (on 1 module), 64 channels all told.
The config operation is like this:
23822iB684F87C716FAFE5
This is called twice, with TC CHANNELS and V CHANNELS describing the channel arrangement.  Both channel descriptors are the same except for device number. The Sample rate works out to 1000 / 100 = 10 Hz. I am using CONTINUOUS SAMPLES, with no need for a buffer, but I understand that one is created anyway.
One loop of my main program is waiting on the READ function:
23824i19385F8722387B7B
You can see the explanation of why the loops are there.
After reading the data (at 10 Hz), each frame is sent via UDP to somewhere, and every 5th frame is displayed, via another loop.
This program runs 24/7 on the same computer as another program.
All this works fine in normal circumstances.
However, occasionally, a weirdness creeps in:
In the mornings, after waking the screensaver (or the CPU itself, I'm not sure), we sometimes (not every time) get a very rapid display - the displays are changing much faster than the expected 2 Hz.
I've been wondering whether the data shown was historical, or simply faster updates of live data.
Today, it so happened that a blower was turned on just before waking the computer. The device takes 15 seconds to ramp from zero up to operating pressure normally, and then it stays there.
The readings on screen were frozen (unchanging).  When the computer was awakened, what my client saw was the reading for the blower pressure ramp from zero to running pressure in 2-3 seconds, stay there for 2-3 seconds, drop quickly to zero for 4-5 seconds, and start the ramp again.
Over and over and over it replayed this data, way faster than 2 Hz.  At least 40 times it replayed this same data, while the real pressure was just variations around the operating pressure.  As time went on, instead of dropping to zero, it would drop to some point on the ramp up and repeat from there.
I don't know if it would eventually straighten itself out - the client gives up and restarts the program.  All is well after that.
I've gone over my code several times, and I can't see a mechanism for me to store this data and re-play it.
Here's my best guess as to what's happening:
Since I am not explicitly setting the buffer size, it defaults to 1000 samples.
Since I'm running at 10 Hz, 1000 samples = 100 sec.
At some point, because of the screensaver, or because of CPU sleepage, or because of integer rollover, or because of zombie infiltration during the night, NI-DAQ has become confused.
When the mouse was wiggled, the gates were opened. After that, whenever I ask for a sample, it gives me one, without regard to read/write position. It continually gives me the next sample from the buffer and wraps around, again and again, and again, as fast as I can read / process / display.
It is also putting new data into the buffer, so that the historical data eventually gets wiped out.
That fits the facts:
  It shows only recent (last 100 sec) data, not ancient data, and not live data too fast, as I had considered.
  The data changes with time - oldest data gets wiped out.
  It plays the SAME data over and over and over.
But that means a bug in NI-DAQ, I think.
QUESTIONS:
Any flaws in my thinking?
Any previous sightings of this symptom?
Any ideas for workarounds?
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 1 of 13
(4,670 Views)
I should amend the description to point out that I have NI-DAQ 8.8 on MY system, but I haven't seen the issue on MY system. But then I haven't run it all night with 50+ channels.
I'm not sure of the client's NI-DAQ version yet.
Steve Bird
Culverson.com
LinkedIn
Message 2 of 13
(4,662 Views)
If the buffer filled and started to over-write the old data, those DAQmx VIs should return an error.
For those type of apps I reverse the order ...
I check the available samples, and read only that many and toss all but the last from each.
Ben
Message 3 of 13
(4,655 Views)
I agree that's what SHOULD happen - just wondering if there are cases where it gets confused and doesn't do that.
I guess checking the error would tell me that, but I can't make it happen (yet) on my machine,
Well, this came about after the fact: I discovered the two chassis were slightly out of sync, so one side's data was older and older WRT the other. So I tacked on the loops.
This seems more economical, given that there will be one and only one sample there 99.9999% of the time.
And I don't see a mechanism for that causing the problem, anyway.
Since that happens rarely
Steve Bird
Culverson.com
LinkedIn
Message 4 of 13
(4,640 Views)
Hi Steve,
The rapidly changing data, is that on the viewing machine or on a display on the device acquiring the data? Does your computer go into any sort of power saving mode where the USB controllers are disabled during hibernation/standby?  What version of DAQmx do you have installed? Can you post your code?
Matt
Message 5 of 13
(4,620 Views)
The "device acquiring the data" is a pair of cDAQ chassis.  There is no display there. It's the LabVIEW program that is reading and displaying the data.
on MY machine, I have tried this with CPU sleepage and such.  Didn't know you could sleep the USB, but on MY machine, that's disabled.
But I haven't made it happen on MY machine.
My CLIENT's machine is actually running XP, and is set to turn off monitor NEVER, turn off hard disk NEVER, and system standby NEVER.
On MY machine, it's 8.8 - I haven't found out from my client yet what his is, but it won't be far away from what came with LV 8.6.
Well, OK:
Here's two of the loops running (the third loop deals with TCP/UDP and is not relevant, I think).
The TCM DAQ manager 's READ function is pictured in the original post.
Here we wait on a sample, scale it (volts into EU), and feed it to the PROCESS TCM DATA vi (which does averaging).
23976i2B9204FEBF4B2CFB
Here's the NEW DATA function for PROCESS TCM DATA:
The ST (short-term) HISTORY is set up as an N channel by 5-sample array, and ST HISTORY SAMPLES is set to 5.
23980i88495C012D6F00AC
The DAQ loop, after processing this data, triggers a DISPLAY event, which triggers a DISPLAY action, which lands here:
The GET DISPLAY function retrieves the latest averages:
23982i44401D2B8B857C3E
That data (64 channels worth) is split into two banks and displayed:
23984i9D50A5586B01B1CB
The display process simply distributes the array data into clusters (channels can be user-configured to be in various locations on the screen):
23988iED4BB057965E9FE6
The UPDATE TIP action causes a TIP STRIP string to be updated:
23986iF9A4C986996718F2
The TIP STRIP shows the average and min and max values (which might be hidden from the display itself), based on which display cell the mouse is in.
23990iAEE02FDEA0706E38
A MOUSE ENTER event on any display cell sets the CLUSTER CONTAINING MOUSE variable to the CTL REF of the event, a MOUSE LEAVE event for the overall display bank (containing 32 cells) sets the CLUSTER CONTAINING MOUSE variable to Not-A-RefNum.
the DISPLAY looks like this (only a few cells shown).  The display for this program occupies an entire 1680x1050 LCD display, another program runs on the main monitor.
23992iC0E2CFF374644CDA
As you can see, the only storage in this process is the AVERAGER, and that is limited to 5 samples (0.5 sec). It cannot store any more than that.
I've thought about the possibility of the mouse oscillating between two cells (as mice are sometimes known to do) when it is parked, and causing a flood of MOUSE ENTER events.
But 1) it happens more often than the odds would dictate  (a random location is not likely to be on a cell border), and
2)  When that cleared up, the queue would be processed, but it would display CURRENT data more rapidly than 2 Hz. NOT historical data.
Given that it seems to be about 100 sec of history (judging by my client's recap of what he saw, and how it operates), that points to the 1000-sample buffer within NI-DAQ.  That's the only place that I see to store that data.
I'll admit that I'm not watching the ERROR output from the NIDAQ READ function. Perhaps I should.
The only scenario I can come up with is that NI-DAQ's READ pointer is confused.
When I ask for a sample it tells me that there is ONE and only ONE available.  So I deal with it.
When I ask again, it tells me the same thing.
It goes round and round the READ buffer.  At the same time, new data is coming in, replacing the oldest stuff.
But it (apparently) never gets back to the "normal" condition, where it WAITS on a sample at the RAD function.
Nobody has waited long enough to see if it would do that eventually, after a few minutes (50+ replays), they give up and restart.
Restarting the program resets the cDAQ drivers, among other things, so the problem goes away.
If there's another scenario to cause these symptoms, I'm all ears. But I cannot think of it.
If it was a USB SLEEP problem, I wouldn't think the data would replay from BEFORE the wake-up. But that's what happened.
Steve Bird
Culverson.com
LinkedIn
Message 6 of 13
(4,612 Views)
Hi Steve,
I guess I’m mistaken, from your first post it sounded like you had two computers, one acquiring data and broadcasting it via UDP to another that is then displaying the information. I take it then that all this is on one computer and the UDP takes place after the data is displayed and probably not related? Is this an EXE running on the customer’s comp? Can you use a debuggable exe and observe its behavior? If it’s a VI can you use highlight execution?
Matt
Message 7 of 13
(4,599 Views)
---The UDP link is to a PXI box, which takes the data, collates it with other data measured in the PXI, and sends the whole mess to a separate program when they run a test. The separate program may or may not be on the same machine as the program in question, above.
--- In this case the problem program and the host program are both running on the same machine.  However, they are not running a test overnight, so the host is not very busy.  The data is being sent via UDP, the PXI box receives it and ignores it (since a test is not running).  I believe that is not related.
--- Yes.
--- I don't know what a "debuggable EXE" is.  Given that the issue only occurs once a day, debugging is difficult.  We haven't discovered a way to reproduce the problem on demand.
--- I have sent a version which includes a timer to note the time between DAQmx READ operations.  That whos 100 +/- 2 mSec on my machine here.  I hope to have the client notice that indicator the next time the issue occurs.
Steve Bird
Culverson.com
LinkedIn
Message 8 of 13
(4,591 Views)
Two programs, one acquiring data via cDAQ, UDP communication between the two, and the second program displaying data? Can you view the data directly from the DAQ device before you UDP it to the other computer? Noting the time between DAQmx reads and the information being returned should narrow it down to whether or not the DAQmx read call is returning old data or there is some other place where information is being stored and replicated. Also, here is document that shows you how you can remotely debug an executable.
Matt
Message 9 of 13
(4,565 Views)
--- No.
The same program that acquires via cDAQ is displaying the data AND transmitting via UDP.  The two loops in the code diagrams I posted (DAQ loop and UI loop) are in the same program on the same machine.
Although it's NOT transmitting at the time of the problem.
The UDP listener is in the PXI box.
I believe the UDP is irrelevant to this issue.
--- Yes, that is what we're judging by.  When the computer is awakened, starts displaying data at a rate much faster than 2 Hz.  This last time we were able to definitively say that it is replaying HISTORICAL data, and it's replaying it over and over and over...
--- But look at the chain from DAQmx to AVERAGER to DISPLAY.  There is no mechanism for any storage, beyond the 5-sample storage in the averager.  The fact that the history is about 100 sec long points strongly to the DAQmx buffer. But if there's some other mechanism you see, I'm listening.
Steve Bird
Culverson.com
LinkedIn
Message 10 of 13
(4,558 Views)
