Why no valley detected
Hi
Something seemingly simple I can not get to work...
Please see the attached VI which contains an array constant (which represents a typical set of acquired data points) on which I perform a peak/valley detection.
I would like to find the valley(s) but no matter what 'width' is used it never finds any valleys.
Any ideas as to why this may be or suggestions on how else to determin the valley location?
Many thanks for your help!
Jack
(2,495 Views)
Accepted by topic author JTRI
Hi there,
You need to wire in a value for the 'Threshold' input. This input tells the VI to ignore any valleys below the threshold value. As there are no valleys in your data set below 0, you will not detect any if you don't wire in this input.
Should you set the threshold value to '800' you will detect one valley. If you set the threshold value to '1200', you will detect three valleys.
Hope this helps.
Dave.
Senior Software Engineer
www.Adansor.com
(2,482 Views)
