Why is the typecast function deprecated?
I notice that the typecast function is placed in the Functions palette under 7.x functions.  Why is this?  It seems important enough to include in LabVIEW 8.x.
S G
Certified LabVIEW Architect, Certified TestStand Architect, Certified Professional Instructor
Message 1 of 9
(4,146 Views)
Not sure what you mean but in 8.2 it is under numeric>> data manipulation.
hope this helps
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 2 of 9
(4,137 Views)
In my version it is under "numeric...data manpipulation"
Message Edited by altenbach on 08-31-2007 04:56 PM
Message 3 of 9
(4,138 Views)
You're right.  What misled me is the search function on the palette.
If you enter "Type Cast" in the search window, and double-click on the Type Cast function that shows up in the list, and navigate up, you'll see that the one that shows up in the search is the one in the 7.x menu.
Thanks to the responders.
S G
Message 4 of 9
(4,133 Views)
Also, a question for Altenbach.  What did you use to capture that screenshot with the red glow around the area that you wanted highlighted?  Or did you manually add that into the picture?
S G
Message 5 of 9
(4,129 Views)
It's just a screendump. The cropping and the red glow was done manually in corel photopaint. 🙂
Message 6 of 9
(4,124 Views)
Do U mean 8.20 or 8.21 ?! I m bemused. In 8.21, it goes correctly to Numeric -->> Data Manipulation palette on double-clicking from Search.
Please clarify me...
- Partha ( CLD until Oct 2027 🙂 )
Message 7 of 9
(4,053 Views)
The 7.x palette is part of the OpenG.org paletteset, and is created to keep up the speed of coding for the ones that are used to the 7.x layout
Ton
My LabVIEW Ideas
Message 8 of 9
(4,030 Views)
I have 8.21 installed.  But it seems like TonP is right, I have OpenG installed.
S G
Message 9 of 9
(3,997 Views)
