‎08-31-2007 06:09 PM
‎08-31-2007 06:55 PM
Not sure what you mean but in 8.2 it is under numeric>> data manipulation.
hope this helps
‎08-31-2007 06:55 PM - edited ‎08-31-2007 06:55 PM
Message Edited by altenbach on 08-31-2007 04:56 PM
‎08-31-2007 07:05 PM
‎08-31-2007 07:08 PM
‎08-31-2007 07:14 PM
It's just a screendump. The cropping and the red glow was done manually in corel photopaint. 🙂
@S G wrote:
Also, a question for Altenbach. What did you use to capture that screenshot with the red glow around the area that you wanted highlighted? Or did you manually add that into the picture?
‎09-03-2007 05:51 AM
@S G wrote:
If you enter "Type Cast" in the search window, and double-click on the Type Cast function that shows up in the list, and navigate up, you'll see that the one that shows up in the search is the one in the 7.x menu.
Do U mean 8.20 or 8.21 ?! I m bemused. In 8.21, it goes correctly to Numeric -->> Data Manipulation palette on double-clicking from Search.
Please clarify me...
‎09-03-2007 10:05 AM
‎09-04-2007 10:57 AM
