Why is my USB camera recognized in MAX but not in LabView?
Thaks for reply yorkdav1, I couldn't solve my problem. If I get a solution I'll post again. Regards!
Message 11 of 31
(3,028 Views)
Message 12 of 31
(3,017 Views)
Hi David,
I know that this is not of any help to you, but I've got a Logitech C920 camera and I can't even get it to show up in MAX. Did you have to do anything in particular to get it to show up?I'm using version 14.5.0f0 of MAX. Any ideas would be appreciated.
Mark
Message 13 of 31
(2,967 Views)
The Blessing and the Curse of Remote Desktop -- I've got a C920 camera plugged into my PC at work (I'm home getting some repairs done).  So I remote in, open MAX, find the camera, click "Snap", and see --- a black screen (the lights are turned off in my office, duh ...).
When I get in to work and get the lights turned on, I'll check to see if this has been solved.  If not, I'll try (and I'm pretty sure I'll succeed) to post code that demonstrates taking a picture.  It's only a little more work to take a video ...
Message 14 of 31
(2,937 Views)
Hey Mark,
Curious. Puzzling. I don't recall having to do anything special to get it to show up in MAX; I don't have the camera anymore so I can't confirm. Maybe check to see if you have the IMAQ software installed on the myRIO?
Sorry I can't be more helpful.
Cordially,
David
Message 15 of 31
(2,922 Views)
Hi David,
Thanks for your reply. I'm not actually using a myRIO (I don't have one), my camera is connected directly to a USB port on my PC. Perhaps that's the reason for my problem - what do you reckon? I have never used a myRIO, so I don't know anything about it.
Mark
Message 16 of 31
(2,913 Views)
OK, now my lights are on (in more ways than one!).  I opened MAX, noted that my Logitech C920 is called "cam3" by MAX, and made sure that a Snap worked.  I then laid down a few IMAQdx functions, shown below:
The first was Open Camera, to which I wired a Constant to the Session In input, then chose "cam3" from the Drop-down choices.  Next came Start Acquisition, Snap, and Stop Acquisition.  Snap needs an Image input which I create with the IMAQ Create function, naming it Snap and saying that it is 32-bit RGB.  On my Front Panel, I place an IMAQ Image Indicator, to which I wire the Snap Image Out.
When I run this, a picture appears of the top of my head (fortunately my whole face isn't visible, preventing my computer from crashing).
If you need to make videos, there are a few more hoops through which to jump, but it is largely a similar process.
Message 17 of 31
(2,897 Views)
Hello Green,
Do you have th Vision acquisition software installed on your computer?
Are you able to see the camera in the windows device manager? or use it in any program?
Randy @Rscd27@
Message 18 of 31
(2,887 Views)
Hi Randy,
Thanks for your reply. The answer to all your questions is yes. This is why I'm so confused.
Mark (AKA Green Giant)
Message 19 of 31
(2,864 Views)
Hi Randy,
Here are a couple of screen shots of the NI software that I have loaded on my PC.
Message 20 of 31
(2,844 Views)
