Why information are not displayed on my front panel array?
I am beginner with Labview, and here is my problem, certainly very basic...:
See attached my VI Example.zip. The current values I would like to be displayed on my front panel array never appear! Why?
Thank you very much,
PB
(2,538 Views)
I'm not entirely sure what you're trying to do, but you can't see it because you're replacing element 1,1 and the first element visible is 2,4. Right click the array border and select Visible>>Index display. Then, change it. You should also place a wait in your loop to allow the cpu to rest. I suggest you read the LabVIEW user manual. Also, try searching this site and google for LabVIEW tutorials. Here is one you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide.
___________________
Try to take over the world!
(2,535 Views)
Bonjour,
Le changement a bien lieu lors de l'exécution du VI mais si vous faites apparaître les indices de lignes et de colonnes, vous n'affichiez qu'à partir de la ligne 2 et de la colonne 4. Or le changement avait lieu sur la case 1,1. On peut faire apparaître ces indices en cliquant droit, éléments visibles. (cf screen shot)
Cordialement,
David D.
Ingénieur d'Applications
NI France
(2,521 Views)
