Why does this VI not work?
I have a VI here, which I'm having a really hard time understanding the error which occurs when I run it.
What it should do is loop through the indicators (they are string indicators set to transparent)  in the cluster and set the caption text to the corresponding value in the numeric array.
Can someone please explain to me why I'm getting an error?
Bjorn
(3,471 Views)
Hi Holomorph,
Once the caption is made visible, on each of the cluster-objects, your VI works! Smiley Happy
...but the reason for the error is: there's no Caption to change - until it's created  - by being made visible [once] first - it can be hidden after that. Smiley Wink
cheers
Message Edited by Dynamik on 12-15-2005 08:51 PM
When they give imbeciles handicap-parking, I won't have so far to walk!
(3,468 Views)
Ah, thanks.  I thought I had the captions showing, but now that you pointed it out, I checked and it was the labels.  😛
"right, what's a cubit?"
Message Edited by holomorph on 12-16-2005 12:12 PM
(3,433 Views)
It probably will still not work, because the VI cannot be running to modify these items. 😞
(3,412 Views)
"right... what's a cubit?"
Thanks holomorph - this reminder made me smile (having forgotten most)
Guess I better get back to work, though,
("voopaah... voopaah... voopah...")
(3,403 Views)
Hi Altenbach,
      Having written an application in 7.1, that dynamically (that is, at run time) changed hundreds of captions, and having tested holomorph's example [repaired] before replying I'm pretty sure there's no problem here - what makes you say so?
(3,398 Views)
Just to clarify, it does work, once I hide the label and show the caption instead; you can modify the caption text at runtime, but getan error if you try to modify the label text.
(3,384 Views)
