Why does the string concatenate slow a loop?
I am concatenating two strings using the concatenate function in a For Loop, and executing the loop 25000 times. The loop executes as if there is a delay in the loop. I am running this test in normal execution mode, NOT Highlight mode.
I understand there are more efficient ways to do this but I am trying to understand the concept why the concatenate slows execution soo much.
Can anyone provide me with some knowledge on this topic?
(3,241 Views)
The concatenate strings function has to create a new string for the output string and destroy the input strings. This is much different from the replace substring (which is much more efficient), where no memory is allocated or destroyed, but rather, the output uses the same memory as the input (only some of the values stored in the memory locations are changed).
Allocating and dealocating memory are time consuming. The larger the memory being operated on, the more time it takes.
-Jim
(3,241 Views)
> much.
Is there anything else in the loop? Perhaps an update to a control or
indicator? Or maybe you are building an array of the output strings.
While concatonate will have to do memory management, I was able to do
25,000 in milliseconds. How many milliseconds depends on the size of
the string, but it is quite fast.
Greg McKaskle
(3,241 Views)
Thank you Jim!
I was asked this morning about what "destructive reads" are.
I thought about the re-use of buffers in a CIN but I was drawing a blank otherwise.
I had never stopped to think about what happened to the input string (I avoid long strings like the plague).
Ben
(3,241 Views)
