Why does the U32 conversion vi truncate my number to 28 bits?
I'm having trouble with the U32 conversion VI in Labview PDA.  I'm trying to converate a double floating point number to a unsigned 32 bit hexadecimal number.  However, the U32 conversion appears to be discarding the upper nibble of the number.  I've attached a simple example which reproduces the issue.
(3,455 Views)
I don't understand the reasons, but it is behaving as you described.  My system: Dell Axim X51v, Windows Mobile 5.0 a4, LabVIEW 8.0.1 with LabVIEW PDA 8.0.1 update.
I'll lurk for any answer you find.
Bob Young
(3,440 Views)
I was able to reproduce the behavior on my end with I32s and U32s so I have filed a corrective action on the issue. This is a bug that I will let everyone know if there is any type of work around or solution found. Thanks
Tyler H.
(3,402 Views)
I found that I could insert a "round to - infinity" vi between the divide VI and the U32 conversion VI and avoid the problem.   It seems the U32 conversion VI screws up when the input has a fractional portion.  It's supposed to truncate the fractional portion, but apparently that's not all it's truncating.
I think I'm up and running using this solution.  However, if there's a patch to correct the problem in the future, please let me know about it.
(3,387 Views)
