Why does my cluster have weird names that I didn't set up?
I have a cluster with good names as I'm expecting and bad names, I don't know how they came from. For the bad ones, I was expecting them to be  "Log.11.label .... Log.20.label"
What did I do wrong to "Log. 1 2. label..." . I'm struggling with fixing them. (I have attached my VI)
Message 1 of 9
(2,162 Views)
Unless you attach your cluster, we cannot tell what you are doing wrong. Maybe there are hidden elements?
What does the context help say if you hover over the cluster wire?
Message 2 of 9
(2,154 Views)
Hi Mr.altenbach,
I just attached it.
Message 3 of 9
(2,152 Views)
Unfortunately that is PEBCAK.  It looks very much like you copied some controls and did not rename them from their default copy names.  LabVIEW will always add an incremental number after the label.  SO let's say you have a control named "A".  If you copy it, the name of the copy will be "A 1".  If you select both and copy/paste, you get "A 2" and "A 3".
And always remember that everything that appears in the cluster bundle/unbundle by name is in the actual cluster.  EVERYTHING.
Bill
CLD
(Mid-Level minion.)
Message 4 of 9
(2,144 Views)
H Billko,
Yes, I was copying controls to save me some time. Is there any way this can be fixed without having to manually create controls one by one?
Message 5 of 9
(2,128 Views)
Accepted by topic author GRCK5000
You need to edit the type definition and name things the way you want them
Message 6 of 9
(2,123 Views)
Hi GRCK,
You just need to rename them as needed.
How else do you define a datastructure/typedef in any programming language? You need to define the labels for each element of the structure/cluster…
Message 7 of 9
(2,120 Views)
The quickest fix is to delete it all and start over.  LabVIEW auto-incrementing labels is a great convenience, but you have to understand how it works.
Create a control inside a cluster and give it a name with any text, a space and any number.  When you copy and paste the control, the text and the space are carried forward and the number increments.  Copy any number of controls, and the numbers all increment perfectly.  It does not even mater which one you copy.
Your labels are missing the text and the space before the number that make it work.
Michael Munroe, CLD, CTD, MCP
Automate 1M+ VI Search, Sort and Edit operations with Property Inspector 5.1, now with a new Interactive Window Manager!
Now supports full project automation using one-click custom macros or CLI.
Message 8 of 9
(2,098 Views)
Actually the quickest way is what Mr. Altenbach said. I did what he said "disconnect the cluster from type def" then change the names. Problem is fixed now.
Message 9 of 9
(2,052 Views)
