Why does it report missing *.dll when running standalone programs on a separate PC without LabVIEW?
I wrote a LabVIEW code to control GPIB, DAQ and Serial port. Then I built an installer including runtime engine. Everything works fine at the PC with the LabVIEW. I copy this installer folder to another computer without LabVIEW. I had no problem to install the program. But after I run the program, it started to ask for nilvaiu.dll. After I copied it under C\Windows\System32\, it started to ask for nimdbgu.dll, then niorbu.dll. Then it reported "The procedure entry point_pkgModulePackageEventLog@20 could not be located in the dynamic link library NIPALU.dll"
I guess it missed some drivers. So I installed NI-488.2 for Windows on the PC. But it did not solve the issue.
(3,289 Views)
Take a look at this discusion forum. LabVIEW Run-Time cannot find nilvaiu.dll
Anyway you need to install NI-DAQ on the target machine.
(3,276 Views)
The problem is solved after I installed NI-DAQ 7.3.
Thanks!
(3,264 Views)
hi there
i recommend to update to DAQ 7.4. the performance is much better.
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,258 Views)
