SQL Server getting 100% CPU running with DSC Engine
Hello all.
I'm working with LabView DSC. I have defined a lot of tags that are getting information. At the same time, the SQL Server (version 😎 is working. This is necessary for getting the DSCEngine working fine.
All is running well, but sometimes the SQL Server process (sqlmangr.exe), gets the 100% of CPU, and the PC is bloqued due to this.
This only stops when the SQL manager service is stopped. Then the CPU is released, but obviously, the DSC Engine doesn't work fine.
Anyone knows about this with SQL Server Manager???
I'm using LabView DSC 7.1 (November version).
Thanks in advance.
Dani
Message 1 of 1
(2,816 Views)
