Why does building packed project library change custom icon size?
When I build small icons using the instructions in LabVIEW help "Creating a Custom-Shaped Icon", and then build the resulting subVI into a packed project library, the icon size changes back to the default. I have attached Sample.zip containing Example calling subVI.vi and Example calling PPL.vi which show the icon size of Integer to String.vi changing from a custom small size to the default size after it is build into a packed project library. How can I prevent this icon resize from happening?
Jim
(4,287 Views)
I see small icon or not understand you
(4,259 Views)
When I call the subVI the custom icon is the desired size.
When I call the packed project library, the icon goes back to the default full size. The border is not visible, but this example shows four copies after being selected on block diagram and  vertical compress selected.
(4,227 Views)
And no error again. LabVIEW 15
Sorry, I don't know why you get this strange result.
(4,206 Views)
Was there ever a resolution to this issue? I am seeing the same problem in LV2016 when I build a "bullet" style VI into a PPL.
(3,610 Views)
When we asked NI this question a while back we were told that PPLs always use a full size icon. We were never given a good explanation as to why though.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,594 Views)
