Why does analog read waveform produce repeat timestamp
I am using a USB-6009 to read an anlog input as waveform and update an indicator (waveform chart).  Occasionally my waveform chart will clear itself and I have verified this is due to the current timestamp being equal to the previous timestamp.  I understand this makes the chart clear but why does the Daqmx Read produce two points with the same timestamp?
I am using the Daqmx Timing function to setup continuous acq, in the range of 100-500 Hz.  My Read function is in a loop with a Wait for Next ms Mulitple equal to 10ms, and I read all available samples in the buffer.
Dan
Message 1 of 20
(4,086 Views)
If these are parallel loops, then you might have race condition. Your read time is equal to your fastest timer rate, so conceivably, you could get the same time (and value) twice. Have you tried a slower Wait?
Richard
Message 2 of 20
(4,051 Views)
Dan
This sounds strangely familiar. I think I recall reading of a bug that fits your description. So first-off, make sure you have the latest a greatest version of the driver.
If you are using the latest version then this may be a bug. Post your code so we can verify.
Ben
Message 3 of 20
(4,043 Views)
What Ben said. I was off base thinking you are just looking at data. Indeed the timestamp should change.
I recall the issue with repeated timestamps being with RT and/or Shared Variables. At least I know I had plenty of repeated timestamps on RT using SV.
Message Edited by Broken Arrow on 11-18-2008 09:03 AM
Richard
Message 4 of 20
(4,039 Views)
Thanks for the replies.
I will update the drivers and see if my problem is solved.  I have extracted the problem section of code and uploaded.
I am on a Windows (non RT) system and use no shared variables.
Dan
Message 5 of 20
(4,020 Views)
Hi Dan,
You did not mention the version your are using so I'll asume you have checked this.
If you replace the "wait Until Next ...." with a simple "Wait ms Timer" with a delay of 100 ms does the problem change? I suspect the actual loop rate is slower than you expect so the delay ends up being a noop. Check the error cluster coming out the the DAQ read to see if you are getting a warning.
Ben
Message 6 of 20
(4,015 Views)
Ben,
I am using LV 8.2.1,Daqmx 8.5.0.f5, but I am in the process of updating to Daqmx 8.8
I tried using a Wait ms = 100ms and still get some equal timestamps, but no error from the erro cluster
Dan
Message 7 of 20
(4,007 Views)
Ben,
I still have the problem with the new drivers installed (8.8).  Is it possible the device is faulty?
Is the timestamp set by the device clock, and if so I guess I don't understand how it could be having issues with such a low sample rate (100-500 Hz).  I have also used this method in several other applications with similar devices without fault.
Dan
Message 8 of 20
(3,990 Views)
Now is the time to wait for NI support to rely to this thread.
I see nothing obvious in the code let them investigate.
Ben
Message 9 of 20
(3,973 Views)
Hello All,
I am looking into this issue.....will hopefully have some sort of explanation shortly.
Claire Reid
Message 10 of 20
(3,962 Views)
