Why do the Learn NI Labview Basic Tutorial Videos not work?
Does not work for me either.
IE 7 and XP 32 bit
Message 11 of 29
(1,941 Views)
Yay! I'm not the only one with this problem, thanks AKA_TG!
Message 12 of 29
(1,938 Views)
I have tried at home with the same result :(. I just got a post from someone else haveing the same problem....
Message 13 of 29
(1,937 Views)
Yer welcome!
Actually I work in a olace where IT security is of high importance.
It drives me nuts.
This might be one of those things.
Message 14 of 29
(1,926 Views)
Sorry for the problems viewing the videos!  The same LabVIEW Getting Started videos are also available on this YouTube playlist:
http://www.youtube.com/view_play_list?p=B968815D7BB78F9C
Hopefully this helps until the problem is figured out 🙂
Message 15 of 29
(1,911 Views)
Thanks, these are different vidoes than the ones in the tutorial, but I will try and find suitable ones for me. I tried viewing the NI website videos again today on different computers with no sucess. I can seem to view You Tube videos and videos from any other website except yours, I hope you can find a solution.
Doug
Message 16 of 29
(1,895 Views)
One thing that usually happens is companys will block flash streaming ports (1935, 80).  You may want to check with your IT department to see if they have blocked these.  It is very common for companies with high security to do this.  Just an additional thought to add for discussion.
Message 17 of 29
(1,885 Views)
In the first message, he said that he also tried the personal computer at home without success, so corporate policies probably don't play a role here.
Message 18 of 29
(1,876 Views)
Thanks for your help everyone, but I give up for now,
Doug
Message 19 of 29
(1,825 Views)
Did anyone ever find a fix for this?
Message 20 of 29
(1,723 Views)
