Publish front panel by webser, but another computer can not access it through web browser
I'm usiang LabView 8.5. I used web server to publish my vi front panel. The computer running labview can access front panel by browser, but other computers in same intranet can not access the front panel by browser. Does anyone can give me any suggestion?
Gman
Message 1 of 9
(6,459 Views)
When you say that other computers can't access the front panel do you mean:
a) They can't connect to your server at all- the browser has a Can't Find Server error
b) They can connect to the server but the web server won't return a web page or returns a 404 "File not found" error.
c) They can connect to the server and get the web page but the remote panel can't be displayed.
If the answer is A then the problem is probably related to DNS settings on your network or firewall settings on the server.
If the answer is B or C then LabVIEW is likely misconfigured.
Nathan
Message 2 of 9
(6,456 Views)
I believe that the remote computers have to have the LabVIEW Runtime Engine (or LabVIEW itself) running on them.  You can easily download the Runtime Engine for free from NI and install it wherever you want.  I think I heard that if you are using LabVIEW version 8.6, the Runtime Engine is not required on the remote computers, which is a big improvement.
Message 3 of 9
(6,436 Views)
The runtime engine is still required in 8.6 to view remote panels in a browser.
Message 4 of 9
(6,408 Views)
Thank you for your help. I figured out what's wrong: The Firewall in the host PC blocked the web publishing.
Gman.
Message 5 of 9
(6,322 Views)
Hello sir,
my problem falls within the B and C category.How can i configure my labview?
Message 6 of 9
(6,044 Views)
engine1713,
Hello! Here is some great information on setting up and configuring remote front panels for LabVIEW.
Also, here are some Knowledge base articles that talk about a few common Remote Front Panel issues.
Ben Sisney
FlexRIO V&V Engineer
Message 7 of 9
(6,024 Views)
I'm running Labview 2009 SP1.
I had the same problem (EVS 1464RT web browser remote panel not showing on computers other than development computer)
I ran an installer that had a runtime deployment included on the non working computer. That fixed my problem
Thought this might help anyone wondering if 2009 SP1 still requires runtime engine.
Message 8 of 9
(5,774 Views)
If you can not connect from a computer off of your LAN, it might be your router.  You can only host form behind a router if your in the Port Forwarding Rage, and your internal IP is static (aka no DHCP).
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KtcSAE&l=en-US
Message 9 of 9
(4,726 Views)
