09-14-2005 11:54 PM
09-15-2005 04:04 PM
09-15-2005 07:52 PM
09-16-2005 04:35 PM
To help troubleshoot this issue I have a couple questions for you: Are you reading the tags in a loop and it takes 10 seconds to update or does the read itself take 10 seconds? Are you using the front panel connections or the block diagram Datasocket VIs? I might suggest switching between the VIs and the front panel connections and vise versa, just to see if you can get an increase performance. I might also suggest just trying to read one tag and see if you get the same decreased performance. This might give you an idea of connectivity. If that does not cause any delays, try reading the array.
Andy F.
