Why do I keep getting error 201435 when I try to run DAQ assistant VI?
I am new to Labview and I need some help. I keep getting an error code 201435 whenever I try to run a simple generate signal VI (see attached). I haven't had much luck finding a solution online and I was wondering if anyone has had this problem with the myDAQ and knows a fix?
Thank you
(3,566 Views)
Accepted by joshjain
You need to provide some signal to the input called Data.
(3,542 Views)
Hello
For some reason that doesn't really make sense to me. I had configured the myDAQ task so that out of analog output port 0 there should be a sinusoid with a maxumum amplutude of 1, and I also set it to run contuniously, generated 10k samples at a rate of 100k. Shouldn't the task be able to generate this signal based on the parameters I gave it?
(3,537 Views)
Oh I think I get it. Is it not possible to use the DAQ assistant as a stand alone function generator? I don't really understand how that VI works. So if I wanted to generate a sine wave output I would need to hook a sine wave into the DAQ assistant and then it would generate that signal at the respective port. I guess that makes sense. Thank you!
(3,530 Views)
