Why do I get Error -41110 occurred at Excel Get Worksheet vi?
This app runs fine on one machine and gives the error on another. What might be the cause of this?
Thanks, Fran
(5,066 Views)
The LabVIEW explanation for this error states "Report Generation Toolkit: You specified invalid Word bookmarks or Excel named ranges." Please make sure that the Excel spreadsheet you are pointing to is the same on both the machines. Also, make sure that you are running the same versions of Microsoft Excel in both the machines.
Ankita
(5,059 Views)
Ankita,
Many thanks. Your response got me thinking. The machine that the app was having a problem with had a copy of the worksheet where the sheet name was changed by the user making it incompatable with the sheet name called out in the app.
Just wish that I knew where this "Error" is defined because I could not find it.
Thanks Again,
Fran
(5,048 Views)
Hi Fran,
I am glad that the issue is resolved. For future reference, for any LabVIEW error explanation, goto Help>>Explain error and type in the error code.
Ankita
(5,034 Views)
