Why can't I print to a Zebra 2746e using the report tool kit?
I have read on here how peoople have printed barcodes from LV by sending commands directly to a zebra printer. I am using LV8.2.1 on a windows xp computer. I am sending EPL2 messages to the printer using the report tool kit, but all I get is a couple of line feeds. If I send the commands from a command prompt by coping a test file to the printer port it prints fine. Any thoughts. I have attached my program.
(2,923 Views)
I tried your code against my printer and it works as advertised. Can you print to other printers with it?
By the way, when assembling a string you should use the Format Into String function instead of a string concatenator with a bunch of inputs. It takes up less room and is easier to interpret when troubleshooting.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,911 Views)
Thanks Mike
What printer are you using and how are you connected, serial, USB?
(2,888 Views)
A PDF creator and a networked Lexmark laser printer.
Mike...
LabVIEW Champion
(2,875 Views)
