Why can't I create UDLs?
ADO is part of the MDAC (Microsoft Data Access Components) package from Microsoft.  It's not installed with versions of Windows earlier than ME.  That's what supports UDL files and other related ADO features.  I recommend going to Microsoft's download page and installing the latest MDAC version on your machine.  They also have some utilities for checking what version, if any, is currently installed.  The Database Connectivity Toolkit requires at least MDAC 2.5.
What you heard from other forums is true - OLE DB is a much better way to communicate with databases than ODBC.  Also, I want to add that Oracle's OLE DB provider is far superior to the one written by Microsoft.
I hope this helps,
Crystal
Message 11 of 15
(1,380 Views)
Greetings Crystal,
Many thanks to you for these good information ... It sure helps.
Ayman Mohammad Metwally
Automation Engineer
Egypt - Cairo
Message 12 of 15
(1,365 Views)
LabVIEW 8.0 and the latest Database Connectivity Toolset.
I am using the Database Connectivity Toolset with MS Access data bases without any problem.
Now, I have to read and write data to an Oracle version 9 Database and I have not any idea how to star.
Is there any one who can let me know the steps to connect to an Oracle Database ?
It seems, the Oracle Database are not like the MS Access where you have an specific Database file that you can just copy to your computer, and then configure it with the ODBC administrative tools.
Simbani
Message 13 of 15
(1,323 Views)
A good place to get started would be the user manual. It contains information on the differences between Oracle and MS databases, as well as how to connect to each.
Jarrod S.
Message 14 of 15
(1,300 Views)
Hi Jarrods,
Thanks. I´ll read again the Database Connectivity Toolset user Manual carefully.
Simbani
Message 15 of 15
(1,296 Views)
