Accelerometer Analysis - Frequency vs Time Domain Integration
I am looking for some assistance on vibration analysis.  I am trying to integrate an accelerometer signal to get the velocity.  I am integrating the signal in the time domain and also in the frequency domain.  After the integrations I am plotting the FFT's to compare the results and the two results are significantly different.  I am trying to integrate a signal produced by an accelerometer calibrator and so I know the correct output I should be getting.   I am getting the correct result when I integrate in the frequency domain, but not in the time domain.  I would appreciate it if anyone could lend some insight into this problem.
Ryan
(6,590 Views)
What analysis VIs are you using?  The Sound and  Vibration has some nice and well tested time series integration functions
Preston Johnson
Solutions Manager, Industrial IoT: Condition Monitoring and Predictive Analytics
cbt
512 431 2371
preston.johnson@cbtechinc
(6,569 Views)
I am using the Sound and vibration library.  I am very far from being an expert in this area though so I could very easily be missing something.  I have attached my program below along with a sample data file.  The accelerometer calibrator signal provides a 10 m/s^2 rms signal at 159.2 hz.
(6,563 Views)
Ryan,
The integral of the Fourier transform is not equal to the Fourier transform of the integral, so I would expect the result you indicated in your original post.
I do not have the SVT toolkit so I cannot look at your VI.
Lynn
(6,553 Views)
Lynn,
That makes sense.
I am using some functions from the SVT toolkit though, that are supposed to integrate acceleration to velocity and not just blindly integrate the raw data.  I had assumed that the information after the two integrations should be the same, just in a different format.   Since I can't show you my program it may be hard for you to comment but do you still think that the results should be different assuming the integrations are operating correctly?
Ryan
(6,546 Views)
Ryan,
I do not have enough information to venture an opinion. You'll have to find someone with the toolkit.
Lynn
(6,533 Views)
Lynn, thanks anyway.  I appreciate any help I can get.
Ryan
(6,530 Views)
