Why can't I build a PDA vi with a formula node?
Hello.
I'm trying to include a formula node in one VI designed for PDA (Pocket PC 2003) but I always get errors that seems to be generated when LabVIEW generate the C file when I make "Build for PDA ".
If the "Execution Target" is LabVIEW for Windows it works fine, but if I try to build it to PDA it doesn't work.
I would appreciate some help.
Thanks.
Nelson Neves
PS: In attachment is a vi test file. Thanks.
(2,399 Views)
Hello again.
Thanks, but I've already found the solution in other post here in forum:
http://forums.ni.com/ni/board/message?board.id=170&message.id=72498&requireLogin=False
Sorry for posting the same problem.
Nelson Neves
(2,393 Views)
