Why can I not re-launch a Matlab script from within LabView after exiting the Matlab application?
I am currently using LabView 6.1 and Matlab 5.2.
When I insert a script node into LabView, I can run it as many times I want to, as expected.
However, if I exit Matlab after executing my vi, I have to exit LabView as well to be able to run the script again. Can anybody solve this?
(2,421 Views)
This is a problem with LabVIEW that seems to be fixed in LabVIEW 7. The fix is to programatically not allow Matlab to be exited.
(2,421 Views)
