Problem to insert an ActiveX Control into a container
I have made an OpenGL ActiveX Control with Visual C++. When I test it into Visual C++ ActiveX control test container, it works correctly. But now, when I insert it into a LabVIEW ActiveX container, it doesn't appear in the VI interface as it did previously in Visual C++ ActiveX control test container. Does someone already get this kind of problem ? If anybody know what is it and how can I solve it. Thank you.
Cyril.
(2,682 Views)
I recommend letting NI tech support know of this issue so that NI can investigate the problem. You can reach them at www.ni.com/ask . Besure to send them stripped down programs with directions for how to reproduce the problem.
(2,682 Views)
